Need Alignment
Phyllis
I have a 2011 Spyder RT with close to 9,000 miles. I noticed the front tires are wearing---one tire wearing on the inside, the other on the outside. I was told I need an alignment. I was also told I should rotate my tires each year. Is this wear normal when you need an alignment? Just asking because this is a four hour fix.:yikes:
The service schedule (in your owners manual) states:
"When tread depth reaches 4mm tires must be removed from the wheels in order to respect rotation direction".
Edit: IMHO an alignment is a waste of money if you don't find out why it went out of alignment like worn parts etc.
JT
