need advice
Spydman
just arrived in gatlinburg tn. Around 4:00 pm for vacation. Trailered the spyder up my droptail trailer. Got the spyder uncovered and untied and got on to crank up and back it off but spyder would not crank?? When I turned the key on it went to the right mode but when I hit the start button it would not make a sound. No lights except the LEDs on the fender. Horn works.no headlights or fog lights. Checked all the fuses and they looked good. Do not want to take it off the trailer because I'm afraid I will never get it back on. Kinda stuck with tomorrow being Laborday. I think there is a Mountain Motor Sports in Kodiak Tn. About 26 miles away. I may haul the spyder over there on Tues.
Sounds to me like you have a dead battery. I would try getting my hands on a charger. Walmart will do in a pinch. Battery is not completely dead just low enough to only light the led's etc. probably find battery down to some thing like 12.9 volts not enough power to turn Spyder over.
Headlights/ fogs won't come on till bike is running to save battery.
Try this..!!
starting proceedure..ignition on..kill switch off..in neutral..step on the brake if not..hit starter button. Now if battery low you will hear a click but if too low perhaps nothing. Having lights and dash does it's thing I suspect the starting proceedure. If it should be the battery perhaps a service station or auto parts store can test and/or charge you back up...:thumbup:
Yes, Mountain Motorsports in Kodak, TN (not Kodiak) is open on Mondays (don't know about Labor Day). Another option you have is Alcoa Good Times, the Spyder dealer Alcoa, TN (just south of Knoxville). Good Times is further away from you but they are a better dealership than is Mountain Motorsports. Good Times is closed on Mondays but will be open at 9 on Tuesday. In any case I wish you luck.
Thanks all for the advice and info. Checked the kill switch and it was ok. Looked at the fuse box again and a couple of the bigger black fuses (the ones you can't see thru) felt to be somewhat loose. Thought I had checked all of them yesterday but anyway I pushed all fuses in tight and :ani29: started up. All seems ok but tonight when putting the half cover on the antenna broke off at the base. Oh we'll I wanted a shortie antenna anyway. Seems like this is starting to be the beginning of the vacation from hell but we will try to make the best of it. Thanks again to all for the help. All the folks here on this forum are friendly and very helpful. :ani29: Friends rock.
Glad to hear you figured it out. Those big black fuses that you can't see through are called Relays and they can come loose.
