TheHammer2021
Read a few old threads back from 2014 or so and no real consensus at least to myself as to the exact method to remove the handlebars to check the steering nut for tightness.
My newly acquired 2014 RT has about 1/2" of play at the bars and it appears to be the top end and not lower, bike rides fine and feels rock solid and stable at speed.
Apparently on older threads most members concerns was with removing the 4 x 7mm Allen head bolts holding the bars down, this part was easy with the right tools ( snug fitting top quality 7mm socket and a 200ftlb impact!).
The plastic ignition surround came off with an 1/8 turn counter clockwise but then that was it.
I really could see no easy or obvious way to actually remove the bar assembly due to the plastic shroud that goes under the bodywork.
Unless one has to remove all of the surrounding bodywork but I would prefer further advice from the experts before tearing into stuff that I might not need to.
Any suggestions as to how to actually access the steering stem nut would be much appreciated!
Thank you and stay safe!
