Baphomet
I took the 2010 RS SE5 into the shop for routine maintenance (8,000 miles on it) and when I got it back I noticed that when I downshift it is REALLY rough. Only when it shift from 2 to 1st does it sound normal. All the other gears it sounds like the clutch is not disengaging and is being slammed into gear. Up shifting everything sounds nice and normal.
In the shop the only thing they did besides check fluids and air was an oil change. They also replaced a device called a "blipper solenoid" which I was told goes on or near the throttle body. They replaced that solenoid because I complained the motor was running a bit rough. The solenoid did correct the rough running issue.
I searched the Owners Handbook and cannot find any kind of adjustment for the semi-automatic (aside from how to shift it manually). I really do not like the service I got from the dealership where I took it for service and don't want to return there unless it is absolutely necessary. If it is some kind of adjustment I can make on my own then that is what I will attempt to do.
So, my question to all you Spyder gurus out there is this; is there a way to adjust a semi-automatics clutch or the timing for shifting? Another question might be for those who live near San Antonio Texas, do you know of a GOOD shop to take the Spyder for service in the future? The shop I took it too is call "Joe Harrison Motorsports" and I was unhappy with their service ... so don't bother recommending them. I could Google a list of shops near here but if someone has a good review for one I'd rather go by that.
TIA
TIA
