Need a Rear Shocker for 2012 Spyder RS - any suggestions?
dicko
The rear shocker on my 2012 RS collapsed a few days ago. It's #706000699 but no one in Australia, US or anywhere an eBay has one. What is a reasonably priced replacement? Is the shocker a standard size (i.e. size used on other vehicles)?
Try contacting IKON Suspension in Albury, dicko. I've sent a few Ozzies that way with some success lately, altho if you tell them that Peter Aawen from SpyderLovers or OzSpyderRyders recommended them, they'll most likely just say 'Who?' :p
They do some pretty good Spyder suspension replacement units, at least as good if not better than much of the more expensive a/mkt gear you can get in Oz; they're just up the road a bit from you; and they'll likely have something that'll significantly improve your ride & handling over the OEM gear; only you might need to talk to them rather than just rely on their website now that your Spyder is no longer a current model; & they REALLY know what they're on about! :thumbup:
There's others here in Oz who'll make exactly what you want too, but I don't think there's anyone closer to you who knows Spyders quite so well as IKON. :ohyea:
https://www.ikonsuspension.com/
Try this mob too perhaps. They may have cheaper options.
https://suspensionsrus.com.au/road-motorcycle/39172-elka-stage-2-rear.html
When you say 'collapsed' what actually happened?
I really meant sprung a leak. The rear-end has been bouncing around a bit. Bouncing it up and down by hand never indicated anything wrong with the suspension. A few days ago it was bouncing all over the place. The seal at the top had popped off so I was bouncing along on the spring only. Could even bounce by hand when stopped. Have made inquiries about getting it re-conditioned.
The ELKA showed up in my searching. Tad expensive. Some others showed up and nothing basically under AU$1000. The BRP catalogue shows $119 but totally unavailable.
Thanks Peter. What was handy was the part-number. I searched that on the internet for comments and came up with this forum. Pogo (whom I've met a few times) was talking about one.
I ended up fitting a Hyperpro Emulsion - Mono Type 460. AU$900 delivered. The ELKA was AU$1550 delivered. The others I looked up were not actually made / available anymore. BRP (AU) didn't even answer any of my emails.
It arrived days before estimated as delivery time included it being assembled.
Appears to be a universal shock whose parts were already in stock.
Easy to fit. Just haven't set the adjustments properly yet. Haven't tried the trailer at all.
