Interesting. I was under the impression that the Juice Box was plug and play?
Anyone know if I would have much benefit adding it to a Spyder that already has: Hindle, o2 mod, Race airflow system & Fuel pressure mod set to 63 psi?
It is "plug and play." :clap:
But you still have to plug it in correctly! :shocked:
The added fuel pressure adds fuel all across the "map" already as the 3 ways you add more fuel to a motor are as follows.
One, increase fuel pressure (more fuel exits injectors in the same pluse time under more pressure).
Two, longer pluse width to the injectors (hold the injector open longer allowing more fuel out).
Three, increase in injector lbs. rating (size of the hole in the injector which means it will flow more fuel over the same time and pressure as a smaller hole will, this size is rated in pounds of fuel).
The added fuel pressure you already have is adding more fuel everywhere all the time.
The Juice Box adds fuel by changing the signals from the O2 sensor to the computer as it intercepts it and adding additional pluse width time to the injectors as it intercepts those signals as well.
The "math" it's program is based on uses what was stock or "normal" fuel pressures when making these changes.
So, the changes it tries to send will always not be quite correct as the "math" is wrong given the increase in fuel pressure. This increase will always cause more fuel to exit the injectors than a "normal" machine with the lower fuel pressure would have.
This will cause an endless, never to be correct hunt by the bikes ECM and the Juice Box, They will be constantly seeking a result the Juice Box is not programmed to achieve with the increase in fuel pressure. :thumbup:
MM
