Need a belt tension spring
jwmorrow
Don’t know where to search, but with all the knowledge on this site, I’m certain someone can direct me. I have a Doc Humphrey drive belt tensioner with a broken spring. Any idea where I can locate a new spring?
Thank you in advance
God Bless
springs
With Doc out of the picture, I think Ace or Home depot may be the easiest. MSC industrial supply has all sorts of springs.
Lew L
If you cannot find the right spring, replace the tensioner with one from LaMonster! Bigger and better roller, have had one on two bikes, an RT and F3. Good luck.
Some of us with DOC's roller setup had bearings fail long ago (Me 2017)
his blue rollers did not have good bearings installed and they did not meet belt RPM speeds
You should be able to get the better roller setup from LAMONSTER GARAGE.
T.P.
