IdahoMtnSpyder
I'm beginning to feel like it's a saga though it wasn't supposed to be! As mentioned in Doc Humphreys' thread, http://www.spyderlovers.com/forums/showthread.php?71934-Pulling-rear-tire, I too am going with a Michelin HydroEdge 215/60R15 for my new rear tire. The OEM Kenda shows wear bars at just over 7000 miles.
First, I ordered a tire late last week off Amazon. Fedex tracking page said delivery was scheduled for Monday, Sept 8. Lo and behold, it shows up on Sat, Aug 30, which is good because I need to get it changed before going on a ride with my brother which we wanted to start on Sunday, Sep 7! So I come home a day early from my visit to the home farmstead 120 miles from here so I can get started on the change.
First step, let the air out of the suspension air bag by loosening up the valve core. Then I take the axle nuts off. I don't believe the manual that the caliper bolts need to come out so I skip that step. Lamonster doesn't believe you need to do EVERYTHING by the book, right? Then I take the nut off the lower shock mount bolt. Now it's time to raise the bike so I start to slip the jack under it. IT WON'T FIT!!! :banghead: Then I remember the air bladder, so back in goes the valve core and in goes air to about 80 lbs. Ah, now the jack slips right under. Remove the valve core again and jack up the bike. Shock bolt won't budge. Back to the jack to lower it. Still stuck. After about a half dozen ups and downs with the jack I hit the sweet spot and the bolt slipped out like a corn cob on a butter cube! Now I fight to get the axle out. Maybe I should have jacked the bike up higher but a rubber hammer against the fixed nut beat it out easy.
Now it's time to juggle the tire out, but wait. The caliper is hung up! Now I believe the book. The caliper won't come out as it binds between the rim and rotor. And I can't get the bolts out as there is no good way to anchor the caliper so I can break the bolts loose. So I'll just push it back on the rotor and line it up with the axle, put the axle back in, and take the bolts out. But nooooooo, the pads won't slide over the rotor and the caliper won't go back in place. Can't get the pads to line up with a screwdriver. Ahhh, but I can get to the rotor bolts to take them out, and the rotor has to come off anyway. I get the rotor unbolted and worked out of the tire and now I can get the caliper lined up with the axle and the axle slid back in place. I get a 15 mm socket. Doesn't fit the caliper bolt. Get a 17 mm socket. Way too loose. What???? Is this a 16 mm hex head? I never have ever in my life seen a metric bolt with a 16 mm head. My Craftsman metric socket set doesn't even have a 16 mm socket! :yikes: So I try a couple of US sockets and guess what? A 5/8 socket is almost dead on the right size. Finally I get the caliper bolts out, take the axle out, hang the caliper from the muffler with a bungee so it won't strain the hoses and wires, jack the bike up a few more inches, and roll the tire out! Yayyy!! It's not much to pull the sprocket off. Rather than brute force it off I worked it off with a pry bar. Came off easy that way. Had to use a deep 15 mm socket on one side and a regular 15 mm socket w/ extension on the other side to take out the bolts that hold the hub to the wheel.
Now it's ready to go to the tire shop. I'm pretty sure the local guys can change it out. I should be able to get things back together tomorrow. Then Wed will be Tri-Axis handlebar install time!
Will follow up with more later, when there's more to write about!
