My Spyder rides "Squirrelly"
+1 on the FOBO, they are awesome - quick glance at the phone and I am good to go - or top off the tires. I had a similar new delivery experience - picked her up brand new from dealer and just assembled, drove it home 65 miles and thought everything was ok (what did I know about handling, etc). The next time out was with a friend and he said my front tires looked low so I checked and sure enough they were like 12-14 so it had to be dealer never fully filled them. Now I keep them at 20 on FOBO and will top up if they get more then .2 psi apart or < 18 and they will swell up to around 23 when hot. Seems to be ok. I do have issues when cornering fast with nanny, but that may be sway bar, alignment or something else.
spring rubbers
if you weigh north of 200# like I do, and especially if you wish good handling when riding two up, then the shock springs are not up to par...as in they are too weak with no adjustability
consider what I did is install "spacers" which are made for the snowmobiles, but also will shore up spyder springs.
Post #5
http://www.spyderlovers.com/forums/...ELP-!!!-Polaris-rubber-spring-spacers-install
+2 on the Polaris spring rubbers suggestion.
Just did that to mine, using only about 3" of spacer on each spring.
Made a nice positive change. We ride 2-up with frunk/trunk and saddlebags comfortably full
