My Heat Vent
Guard has 3 bolts very easy to take off,cutting hole very simple,4 pop rivets
I painted the vent with high temp paint
I would say less than 30 mins. total
Do you have to remove any panals? I removed the 2 screwed directly to the frame and the one bolt under the air dam..that one seems to be attached to several other things, couldn't get the guard off Guess I'll have to wait until my next service and ask the to leave it off
No panels have to be removed, the 3 bolts ,2 in frame,one in air dam
The one in the air dam has a nut and a e-clip. you have to remove the e-clip to get the nut off,then pull the panel it should pop right out I believe all bolts and nuts are 10mm
Hope this helps
Ahhhhhhhhhhh. I think I'm understanding now. I've never been underneath my spyder so apparently there are two pans or guards?
One underneath where you change the oil and one further to the right? Sorry, but I'm just not mechanically inclined.
Chris PE# 0004
Hope this helps
oh yes.a dang clip, good to know Guard came right off:clap:
I think I will leave it off and go for a ryde... decide what I' \m going to do (leave it off or install a vent)
Lamont, I think you have said you removed two guards. Which is the other is for easy oil change?
BTW: Thank You so much for this forum, it has been a true blessing!
well it was noticably cooler...but still HOT. But I guess there's no getting around that when it's 98 f out :yes:
