Have had my Spyder 2013 RTS SE5 for about 2 months now and today got check engine light. Immediately checked the oil level and it was low so added oil, still came on. Time for some research. Found out how to get the codes up and got P0127. After doing more research found that it is high temp air intake. The temp gage showed running in normal range so called the dealer. Live in Phoenix and our daily temp are now running around 110 and nothing I can do about the temp of incoming air. Was told not to worry about that code as long as it was not over heating. They were aware of the problem and been in contact with BRP to come up with a fix and to just ignore the code as long as I don't over heat. That was a relief being I was afraid that it was something major. Every day is a learning experience but I am loving my Spyder.
