jrbloise
Carlo,
I really hate to complain, but I'm going to express my experience with the front tires prematurely wearing of the tread on the insides of my tires.
History: I purchased an 2009 SE-5 RS about mid march of 2009 In Nashville, TN. Note: after a bad experience during my 600 mile service with "Jeff", the service manager, I chose to use MidSouth Motoplex located in Clarksville, TN for all future servicing.
First tire tread problem:
During my 6000 mile service I pointed out the bald tread on both front tires to the service mgr., and Spyder Tech. I noticed the wearing treads at about 4000 miles. Here is what they told me, and I quote, "this is normal wear and generally motorcycle tires are good for anywhere between 6000 and 8000 miles". Also told: "this is probably caused by aggressive riding".
This mildly irritated me, but I accepted the explanation and went ahead and purchased two new tires and had them mount them.
I belong to Spyderlovers.com forum (ID: jrbloise), and read many other posters with the same problem. It seems "up in the air" as to who is responsible for alignment: BRP at the assembly line, or the dealer when prepping. It doesn't matter to me who and when, but I do firmly believe that it should have been properly aligned before delivery to me!
Second tire tread problem:
During my 12,000 mile service, the front tires were bald on the insides again. But this time, the original Spyder Tech. had quit and was replaced by an existing mechanic who is known as a "Master Mechanic" at Motoplex. This guy quickly noticed the tread wear and told me this was not normal and the bike needed an alignment to correct this problem. At this time I asked the service counter person if BRP (or dealer) would make this right by replacing the tires at no cost to me. I was told NO as tires are considered a "wear & tear" item and BRP would not cover them under warranty.
I reluctantly accepted this and proceeded to purchase another set of front tires along with him aligning the front end. I was happy at this point because I thought this Mechanic would finally properly adjust the alignment, and my tread wear would at least be "even".
The Glass is half full/empty:
At the present mileage of just over 21,000 miles, the left front tire (from sitting on the bike) is wearing evenly. But, the right tire is balding again on the inside but not as bad as before.
Now about the "Glass is half full/empty" I think the mechanic who aligned the front end (at about 13,000 service) did the best he could with the instruments available in the shop. I talked with the Service Mgr. and specifically asked him what instrument(s) the shop was equipped with in order to properly align the Spyder. Here's what I was told: "a tape measure".
This is not acceptable to me! And it's yet another reason my tire(s) are going bald way too prematurely! It is also not acceptable to me that I had to spend way more money than I should have in purchasing tires and paying $70.00 per hour for the labor!
I am not stupid and have done my due diligences in researching this problem. I do have an online Service Manual for my bike and read the process for correctly doing a front end alignment. I also noticed an instrument mentioned that BRP provides dealerships with in order to do this job the right way. I know the dealership might/might not have to purchase this equipment from BRP, but just the same they should have something better than a "tape measure".
At this point:
Carlo, at this point in time, I would ask you to "go to bat" for me with the "powers to be" at BRP and satisfy my request.
I would be happy and content if you could arrange my dealership to replace both front tires ,and more importantly, to perform a correct and properly done alignment at no cost to me.
Thank for your time and consideration,
John R. Bloise
VIN: 2BYJAHA129V000518
Model: A29M
Cell Phone: 615-517-6039
At this point:
John R. Bloise
Model: A29M
