My brake wear history
BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
I just returned from a vacation trip ( 750 + mi. ) before I left I had all tires replaced and checked the rear pads..... I changed the orig. OEM pads at 30,000 mi ( and one side was TOAST ).... I switched to BajaRon's pads. The rears start with 4 mm thickness .... mine are down to 1.1mm at 40,500 mi. and feel fine..... I will wait till the end of this riding season without any worries that they will wear out this year. ...... Ron's pads are waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay better than the OEM's. Ron has said many times folks change Pads long before they need to, :agree: ( mostly due to Dealer hooey :roflblack: ). I suspect this will be my last brake job before I give up riding due to age ( 75 yrs old now ). I have a 14 RT which I bought new ....... Hope this helps someone ...... Mike :thumbup:
I just returned from a vacation trip ( 750 + mi. ) before I left I had all tires replaced and checked the rear pads..... I changed the orig. OEM pads at 30,000 mi ( and one side was TOAST ).... I switched to BajaRon's pads. The rears start with 4 mm thickness .... mine are down to 1.1mm at 40,500 mi. and feel fine..... I will wait till the end of this riding season without any worries that they will wear out this year. ...... Ron's pads are waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay better than the OEM's. Ron has said many times folks change Pads long before they need to, :agree: ( mostly due to Dealer hooey :roflblack: ). I suspect his will be my last brake job before I give up riding due to age ( 75 yrs old now ). I have a 14 RT which I bought new ....... Hope this helps someone ...... Mike :thumbup:
Don't change your pads too soon and don't give up riding too soon!
Thanks for the update!
What's the best way to know when pads need changing, before it's too late?
Well I wouldn't trust most dealers on this ...... My measurements came from using a digital caliper tool ($12.00 from Harbor freight ) used AFTER removing the Caliper assembly for access . ... I'm very fortunate in that, I have a ramp into my basement. I have a removeable cover ( 12' X 8' ) I back my RT in onto a 12" wide plank that extends 1 ft. past the edge .... At that end the platform is 4 1/2 ft from the floor .... so my access to the caliper is about as good as is possible ..... that's how I get very, very accurate measurements ..... Mike :thumbup:
:roflblack:. I suspect his will be my last brake job before I give up riding due to age ( 75 yrs old now ). Mike :thumbup:
BS - Like me and many others you'll likely be buried along with your Spyder, sitting right on top of it. :lecturef_smilie: :ohyea:
Here's what I found. Keep a close eye on your rotors as the pads wear down, by rubbing both sides with your fingers checking for any slight marks of gouging by the backing plates. Hopefully, you'll find none. Get an adjustable dentist mirror from Harbor Freight and a small flashlight, and here's the hard part. Lay down next to your spyder and check both ends of your pads next to the rotors. You can keep a good assessment of the pads as they wear down. If you find a pad with one end of the pad being thicker/thinner than the other end, then the pads are not wearing evenly, thus you have a sticky caliper disc. I'm like most everyone else, I change pads long before they need changing. Last if not least, when you're done, call your wife to help you back up off the floor.
Pete minimum pad thickness is 1mm. If you want to check them easily use the edge of a credit card.
If you monitor what's happening with the pads 1 mm is 25% of the start thickness when new ..... I just got OVER 40,000 mi. on my current set of rear ( BajaRon's ) pads ..... so the math says - another 7000 mi. should be safe .... my current pads are wearing very evenly and should continue to do so..... because I can easily check ( and measure ) them, I'm not changing them now ..... JMHO ./... Mike :thumbup:
2dogs, that's exactly why I'm getting that Big Blue lift! Can't always count on Jane being there to save my sorry a**
How are your rotors looking Mike, still in spec?
If the rotor gets SCORED ( ie marks ) it's done, pro's can polish it , however I doubt you'll find anyone who still does this .... " eyeballing" pad width is basically a GUESS ..... I'd rather actually measure them to be sure ..... JMHO ..... Mike :thumbup:
Well I just " caliper " measured FOUR credit cards .... 1 @ .5mm ... 2 @ .6mm ... 1 @.7mm .... using a cc for measuring is like using a " Tire calculator " ..... it's close ....maybe ..... JMHO .... Mike :thumbup:
That's not something I have measured ( accurately - yet ) ..... I did feel for the outside edge ridge that very slowly forms as the rotor wears ..... I have 70,000 + miles on mine ..... the ridge is barely there ..... hope this helps .... Thanks ...Mike :thumbup:
The credit card trick seems to be a common measuring device? Belt and brake pads so far, as long as you use the same card. But, if you change banks then you'll have to start all over again. LOL I use a credit card as a guide only. As far as scored rotors go that's an individual's call. If the score marks are not deep I've reused rotors several times because it doesn't take long for the pads to seat in and I've never had issues with them. And regarding the ridge on the outer edge of the rotor, I've replaced the pads all around once and I've not developed one yet. No experience with that so far.
" Common " but not really accurate ..... I have six other cards I can measure, the four I mentioned weren't close to 1mm .... To me Bad info is worse than No info ..... JMHO .... Mike :thumbup:
So, if you know your CC thickness it could possibly be a good reference tool to judge your brake pad thickness? I think I could go with that.
Inflation Credit Card note: with this year's high inflation, the normal credit card thickness of .5mm has grown to 1mm thickness !!!!! :yikes::yikes::gaah:
???? .... well if you use a " caliper " to measure the cc, why not use it to measure the PAD and save a lot of guessing ?????? ..... JMHO ..... Mike :thumbup:
