my $66.** RISERS
Guess I'm not too good at this.
The hardest part was drilling the little alignment hole for the throttle. When you pull the throttle side apart.You will notice it has a little hole to lock the assembly in.That keeps it from moving when you throttle the bike. Also on the clutch side I wound putting the clutch handle on the back side of the dog bone.Because the dog bone is a little thick and was hitting the resevoir.Looks like you could grind just a tad off the bone and get by ok. I just didn't really want to take any off of mine. It works just fine the way I have it now. I installed my bones and rode it down the road before I Cut off the ends of the orig. bars. You will need a cut off wheel or saws all & 2 7/8 od bars to install your throttle and clutch handles on.
Thanks for the input, wish it had arrived Friday. Truth be told, for someone like myself, my Shadetree has no leaves. I would have been better off with the other risers. For instance, did not have enough pipe for 1 side, let alone 2. Finding the correct size was not easy. I saw the little hole, I'm hoping the Syder Gods get it drilled now that the pipe is installed, without a hole. The right side, with all the running around I had to do, took 6 hours. Left side next weekend, I'm praying. For me, this was a 'penny wise, $3,000 foolish mistake but the right side will look good when I find caps. Think I'll stick to what I know best and when I find out what that is, I will. Have a great day.
