10 min or so
I hope the factory amp is that easy to get to it n my wife's 2016 RTS. Planning on upgrading her amp as well. Will most likely swap speakers as well.
The radio is altogether different in the pre-2020, maybe pre-2018s RTs. There is no separate amp. Read BlueKnight's posts about upgrading speakers. He says the factory radio has plenty of power as is. Just need better speakers.
The 2021 - 2017 models have an output on the radio for the optional CB. The audio volume in the headsets is controlled by the handlebar controls and by the passenger volume control. This leads me to believe that the output from the audio to the optional CB has variable line level outputs for both front and back. The CB outputs are used for the optional Bluetooth audio dongle, which is probably just for the front audio. I don't know why these outputs could not be used to input into an amplifier.I do not know of any way to add an amp to that radio without major surgery. You would need to intercept the signal to each speaker and add an amp in between.
Finless Bob did a lot of research on the output of the audio and came up with the harness needed to connect the Sena SM10 BT adapter to the audio. He hasn't been active on here for several years but I believe he can be reached on FB. Also, Motorcycle Dave has, or at least did have, the harnesses Bob came up with for the SM10. That harness could maybe be used to feed an auxiliary amplifier.
I added a 400 watt Rockford Fosgate amplifier and bypassed the factory 20 watt per channel amp. I made my own wire harness and it is all plug-n-play. Now 1/4 volume is like being at a concert! Am I the only person to do this on the spyders with the new dash? Oh , and no more parasitic battery drain. Problem solved.
What did you use to build the harness?
