Bob Denman
Since one of these horns is now a WinterTime project; I'm sure to be emailing you guys with tons of questions!
Would these horns not be annoying, and irritating to the general public. With their very high decibel level ?----Budro
Hopefully !
I installed the horn just like the instruction stated. just like your project. every time I touch the wire to the battery the horn blows. had someone else look at it and he stated I was installed just like the instruction stated. so what could the problem be. don't understand. something I did find out the red wire is hot all the time on the stock horn when you take a tester to it and the - wire black wire is also hot. so when you push the horn button it is neg. to complete the circuit. the horn blows. have any ideas. help.
yes I the relay that came with the horn. tried again as instruction it still blows when I connect to battery. the relay must be bad I guess
and I think I'm going to try Jack's wiring solution, and disconnect the relay entirely and run the stock horn leads directly to the Stebel.
