Motorcycle Dave's gel seat pad and seat heater can they be used together?
Hi Bob
And anyone else who has the same question, the answer is YES
All you do is install the GEL into the seat so it is flush with the rest of the seat foam
then put the seat heater on top of the memory foam on top of the GEL plug in the power wire
and cover the seat with the smoothing foam to hide everything then put the seat cover back on
install the power switch where you want it then run your wires to the battery or to a port on the
fuse block that is powered up when you turn on the key. it has it's own inline fuse. That's it
it works great and will last for years so you will have a warm and comfortable ride.
Above all RIDE SAFE
Dave
Has anyone installed motorcycle Dave's gel seat pad and his seat heater together?
Bob
