Monster upgrade
Dray
O.K., I have been keeping an eye on all the comments on here about Monster s/w upgrades and I need some
serious opinions on what level of upgrade to do. This will happen to my 2017 F3L which has a top speed of about
85 mph due to ECU closing down my throttle input. I generally take one or two long trips every summer and I will
not ride behind trucks. I have seen what happens when a truck tire comes off the rim. My 2015 F3L would run 115 mph
with throttle to go and passing anything was quick.
So, I am needing input as to which level I should have installed. The bike has a cat delete pipe and a good flow muffler and
I do not hotrod or race the bike.
Feel free to jump in here with your experience and recommendations.
Thanks in advance.
Dray
Wick-It Performance in Shreveport is the USA vendor for Monster. Give them a call with all your questions..
Wick-It Performance
1725D N Hearne Ave, Shreveport, Louisiana 71107, United States
(318)562-6961
Thanks in advance.
Dray
I have a 2017 F3 Limited and mine will do over 100 MPH. You may have something wrong somewhere for it not to go over 85 MPH
I also just question your top speed and the trouble with trucks, I to have seen a strip of rubber fly off a truck in Tx some years ago just when it lost the rubber and pasted me in the same lane about head HIGH. My other question passing trucks at all, and what speed you need to do this in. Tx montana, SD ND and many points west have speed limits of 80 but as the years have gone by most trucks are monitored very close and as i have noticed are not the trouble in the roads as they do not travel at those max speeds when HQ could come down hard on them.
but toping out at 85 seems strange. I have issue when cars pass ME on interstates and they at times are not nice about getting out of lane fully to pass. Im not a slow driver but I surely have stopped over speeding. Trying to live a little longer than I thought I would 50 years ago
:ohyea: …. and if you have OEM sprockets you should much better than 85 mph …..jmho ….. good luck …. Mike :ohyea:
I also have a 2017 F3 LImited which is stock. It will surpass 100 mph with a big F4 windshield, not sure how much higher it will go. These motors require appropriate back pressure, what was your top end before modifications ??
johnv
Call wick it performance...I recommend the stage II... especially since you have a cat delete pipe installed on yours.
hi Dray
i have Monster stg1 and its fine(i havent done any WOT runs tho)but it runs up to 85mph effortlessly so i would expect it do the ton
i have standard exhaust up to the muffler,and then a baffled akra
i will not be changing the tune...i cant ride this bike to its limits anyway and love the power spread just as it is(also love the addictive intake howl)
rpm limit is raised(not necc IMHO) but once you change gear at over 8grand...well,lets just say i wont be doing it again...i want the gearbox to last forever:yikes:
im not sure but does your agent allow upping to stage2 for the price difference,if you already bought stage1?
Stage 1 is thumbs up:thumbup:
russ
just an afterthought...re overtaking..these tunes just make the bike so much safer to ride....2nd or third gear from around 4grand and the bike just rockets...you can pass traffic with much less time spent on the wrong side of the road,espec if you are a big guy or have high combined weight on the bike:clap::clap:
Thanks Guys for all the input!! I will just call the guys and see what they recommend. I may have to change the
gearing to get what I want.
Thanks again.
Dray
there is no changing the gearing
I am hoping someone can figure that gearing change out...I have everything to change my 2014 RTS from the stock 79T set up the 89T set up...MFI was working on it but never got it figured out...They had it working on 1 RT but shortly after he thought he had it there were shifting problems that he couldn't cure...I'm sure there's a way but no one is saying if they did figure it out...
Larry, don't hold me to this cos it's only a supposition, but I wonder if you could possibly get the 'driveline' side of things to work with the different gearing if you changed the Country specification in the BUDS set-up to Australia or Europe.... but I suspect strongly that if you did that, the engine & gears etc might work sorta OK, but you'd VERY LIKELY have all sorts of issues with other things, like the headlights, the radio/sound system, & quite possibly more!! :shocked:
That said, from what I've seen & heard about this, I reckon BRP has very carefully designed their various Control Systems to prohibit any ability to change the gearing like you want to - as far as their various computer control systems and their integration is concerned, you'll only ever get what you already got! :gaah:
HEY DRAY, I think you have other issues going on that need to be figured out before you do an ECM flash or talk about a gear swap.
T.P.
BRP has it working with the F3's...Some with 79T and some with 89T...I'm sure its doable, but way out of my league...I recently talked to Steve at MFI about taking my RT to him with the 89T set up installed and letting him work it out...He said he'd try on my dime but no guarantee$$$...So for now I plan to upgrade from stage 1 to stage 2...I think the 89T set up on the heaver and often ridden 2 up RT's would be a win win...larryd
Once I was behind a flatbed truck that was hauling bricks and a couple came off of it and just seemed to hang in mid air right in front of me, kinda scarey. Another time I was following a truck and some sheets of drywall lifted outa the truck and just seemed to hang the before slamming into my windshield on my 84 VW Beetle on a two lane bridge with no where to go. Don't know how we survived either but here I am. Sometimes ya gotta wonder how we are still alive. Just the luck of the draw I guess. Good luck with your problem. Something is definitely wrong with it only goin to 85. Mike
