bluestratos
After 2 1/2 years and many bandaids later I am going for broke. Here is list of what I am doing (pictures to follow):
The stock air box blocks off the air getting to cylinder heads and makes maintenance difficult. Removing this really opens up the engine and improves passive cooling. I have been using the block off plate on the upper vent up to now but heat leaks out all around it and of course out the bottom vent. I have eliminated this problem now.
The fan can has already been proven to work based on the commercially unit that is available. My "can" took two hours to build, is light weight and duplicates the function. The hot air is now forced in the opposite direction and down out the bottom. The lower stone guard has been removed and modified to allow for air to be pulled down and under the bike.
Obviously the heat has to escape somewhere and when driving there is a high pressure area in front of the engine and a low pressure area behind the radiator so vacuum pulls the heat away is why I have heat coming through my gas door in the seat and up and around where it fits against the body panels.
Idling will always be a problem and likely will still have issues but the hot air will be controlled around the seat. I know Dave has added a bilge blower to improve circulation at an idle and this may be what I will want to do to keep cool air coming in during idle. If so I will figure out how to have it come automatically once the heat rises much like the rad fan.... Ideas?
The bike is still apart in my garage (the wife's car is outside so I need to buy her something nice, lol). I am taking pictures as I go so once the work is done I can add them.
- Removed cat and replace with wrapped Y Pipe
- Removed header pipes and wrapped
- Removed the fan shroud and built a fan can from a 5 gal plastic bucket by cutting out the bottom 3 inches. Perfect fit around electric rad fan and forces the hot air away vents by the right foot).
- Installed thermal blanketing on all body panels including the left and right engine covers
- Installed thermal blanketing up and over the engine and down and under the fuel tank to keep heat way from tank and seat
- Removed all intake plastic and installed ISCI filter/intake
- Blocked off both upper and lower vent openings by right foot
- Installed "Engine Ice" antifreeze to help improve engine cooling
- Installed Magnum Tuner to richen up mix to compensate for other changes and to lower engine temps.
