Microsoft Streets & Trips 2010 Download to Garmin 660
coastrider
I have a 2012 LTD with the factory Garmin 660. I was unable to download a route I created in Streets & Trips 2010 to the unit. I got bounced to a website everytime I tried. Must the Garmin be configured? Do I need a later version? Thanks.
are you sure the garmin supports the M$ software, and other way around?
Here is a video on how to do it via map source (Garmin PC software) you can also do it vi google earth.
I some times take google maps into google earth then export out to garmin
harry
You can also copy the exported "gpx" file from S & T on your computer directly to the gpx folder on your 660 (connected via usb cable in mass storage device mode) via Windows Explorer. Then disconnect usb & restart the 660 in normal mode and it should ask you to import user data. If not go to tools, my data, routes and select the route to import. To load the route hit Where To? On the main screen and scroll down to Custom Routes and find and hit your route.
Spyder Phyl
