Magic Man
Registered User
The gasket must be all the way inside the 90 degree pipe to the ends of those relief cuts.
To ensure this during installation, the gasket goes in the end of the 90 degree pipe before slipping it over the Spyder's exhaust header. That way, when pushing the 90 degree pipe onto the exhaust header you will force the gasket all the way inside the pipe to the ends of the relief cuts. If you put the gasket on the exhaust header first (the easiest way to install it), the 90 degree pipe will force it all the way onto the header instead of inside the 90 degree pipe.
Is this right? I have the gasket on the header not all the way down the 90. Thanks?
Call me I'm at the shop looking into this I think I found your problem.
MM
