Memorial Day ride spoiled by codes!
Here is a list of codes I found online, your code is here:
http://files.meetup.com/1689470/Spyder Codes.pdf
It is always helpful to make sure the battery is running at full power and the connections are tight - more info on that can be found by searching the forums here.
Also try removing the key from the Spyder (and taking it some distance away) for seven minutes to completely re-set the system.
Addition:
I just noticed your post count, so you most likely know most of this!
Little checking..!!
looks like you have a vaccum leak to/from the throttle body. If possible pull the side panels and check the hoses...high heat in engine compartment can dry them out or age...hope its an easy fix and your up and running soon...:gaah:
You guys and this website are the best! Especially the Spyder codes app! My vacuum lines were bad. Spyder is running good again and the codes are gone.
While changing the vacuum lines, I noticed this. Should I be worried or is it just surface cracks?
Intake tube between the throttle body and the head? Vacuum leaks can/will cause a host of driveability issues. I say if it's running good, leave her be, and put it on the list.
