You are so right PMK, I live in FL, and it's 40 miles to my nearest dealer I avoid going there if possible, not because it's bad, but because it's a day out of my life just sitting around doing nothing. If my Spyder did not fire up and run for whatever reason and I could not fix it, that would be double trouble.
Wow, a serious day trip to get there early and get it done. Worth every mile if you trust your dealer and the Spyder mechanic.
Chipveres, not busting your butt, simply, Florida is a pretty long state, North to South. Also has reasonable distance East to West.
Additionally, besides maybe a hint of your location, are you intending to have the work done by a Spyder dealer, or hopeful to find an independent shop or tech.
FWIW, as you probably already know, there are only a few good shops here in Florida. Far more shops to avoid, than there are shops to trust. There is also a few independent techs.
mechanic wanted in florida
as well as 49 other states and a few territories.
Recommendation of Central Florida Power Sports duly noted. If I demanded egg in my beer, the mechanic would be an independent in Greater Miami. Recognizing the likely futility of this, we are willing to make a trip to any other part of the state.
OUCH!!! :yikes:
Overall, BRP has a good product with the Spyder, it's too bad they don't exercise more control over the dealers and the tech's. But then that's probably a problem with most of the motorcycle brands. Most dealer's are now charging $125/$150 an hour work on the Spyder, to me that's high dollar.
