Master cylinder heat shield/deflector
spyryder
Looking in the parts catalogue all '08-09 Spyders had a heat shield bolted onto the front of the master cylinder. This should be an easy retrofit on newer models having overheating problems in the master cylinder area.
It's the RH Deflector #27, p/n 707600580
[TABLE="class: gv, width: 0"]
[TR="class: highlight"]
[TD="class: ReferenceNumber"][/TD]
[TD="class: PartNumber"][/TD]
[TD="class: Description"][/TD]
[/TR]
[/TABLE]
Don't know..!!
have not seen the ST set up and if they have a heat shield. If they don't this could be the solution. If they do this will do little. Don't know if any re-positioning was done.:dontknow:
ONLY the '08-09 models had this heat shield installed. Certain (but not all) newer models including the ST have a deflector welded onto the exhaust pipe in front of the master cylinder.
