Mapping Application
Apologies if this has been posted before.
If you have a limited RT with the Zumo 660 (or if you have a Zumo at all) there is a free download from the Garmin site called Basecamp.
Once Basecamp is loaded on your computer you can custom build a route with all the turns and roads you want to travel. It isn't quite as user friendly as Google maps but it isn't bad.
Once you get the route you want just load it onto the Zumo and disconnect from your computer.
To access the route go to 'Custom Routes' on your Garmin and select the one you mapped out. Don't go to favorites and just click on your destination as that will not work. You must select the custom route that goes from point A to point B as opposed to selecting a destination from your present location.
If you have learned to use Basecamp successfully what will you charge to train me? Normally software is easy for me to get. Basecamp is not so.
