I found this...not sure if it is the same but this was for the F3:
Here are the intervals for the 1330 ACE:
- Replace Oil & Oil Filter: 1st Change at 3100 miles, 2nd Change at 9,300 miles, 3rd Change at 19,000 miles, 4th Change at 28,000 miles. If you don't put that many miles on your Spyder you should change it annually.
- Spark Plugs should be changed at 28,000 miles
- Fuel Filter changed at 19,000 miles
- Air Filter changed at 19,000 miles (replace & clean housing more frequently in duty and wet areas)
- Engine Coolant change at 28,000 miles
- Drive Belt check and adjust as needed at every oil & filter change
Here are the intervals for the 991 engine:
- Replace Oil & Oil Filter: 1st Change at 600 miles, 2nd Change at 4,600 miles, 3rd Change at 9,300 miles, 4th Change at 14,000 miles. If you don't put that many miles on your Spyder you should change the oil and filter once a year.
- Spark Plugs should be changed at 14,000 miles
- Fuel Filter changed at every 19,000 miles or 5 years, whichever comes first
- Air Filter changed at 4,600, 9,300 & 14,000 miles
