Madstad footrests - heat issues?
yup..............Spyderpops has a block off plate that many have installed with no reported problems? Go to the "home" page and click the link as he is a site sponser.:thumbup:
OK.. ordered the upper blockoff. Looks like that'll work. Thanks
Most likely have to do the same thing with mine.............just installed a set of Lamont's NBV Highway Pegs. Let us know how you make out and whether you notice a significant difference?
:yes::yes:Spyderpops.com has a heat shield that works great. just put one on my RT with NVB foor pegs Item# 111 on the spyderpops site
Billiam333:bowdown::bowdown::bowdown:
I put a set of Madstad footrests http://www.madstad.com/s.nl/sc.7/category.3580/.f on the wife's RT. Problem now is the right foot is getting blasted from the upper "vent" space. Is there a way of blocking off the heat without creating overheating issues with the engine?
OK... just got around to putting on the SpyderPops heat shield. Per the instructions, I removed the right floorpan. Doing this exposes a lot of stuff. Has anyone trimmed the floorpan rather than totally leaving it off? Pix or description would be helpful.
I took the pan off and used my holesaw to put 3 - 4" holes in the pan. I also drilled a couple of smaller ones and put it back on. We have ridden many days in the West Texas heat with no problems since then. Although I haven't heard or read anything about any problems just leaving it off either. Most people leave the left pan off to make for easier oil changes
