Made rest for foot
bgame
IMG_0305.jpgMade out of Aluminium ... held on with one stainless bolt.... bent at a angle that when you put your foot on it puts pressure on the floorboard and not the plastic wing. Nut is hidden inside the plastic wing.
Very nice!
simple and effective! Is that an SM6 or SE6? If its an SM6 (and depending on your price!) I would be interested in purchasing a set from you.
Did this on my SE6... Don't sell them... but 2 1/4 inch bolts and about 8.00 worth of plate.... you can make them... drill one hole and bend the plate.... simple... Took a piece of cardboard.... made a pattern that I liked.... trim and cut the cardboard to the shape you like then trace it to the plate....
I like the simplicity. Nice job!
Used nylon locking nut and it has never got lose in 2000 miles.... but it is one bolt on and one bolt off.... Like I said the pressure of your foot keeps the pressure of the plate on the foot board not on the plastic wing....
Floor boards
View attachment 95727Made out of Aluminium ... held on with one stainless bolt.... bent at a angle that when you put your foot on it puts pressure on the floorboard and not the plastic wing. Nut is hidden inside the plastic wing.
I'm in the process of making my own floor boards. They are coming along quite well and I will post pictures when they are completed. I have a 2012 RT and still have the hot foot. When I'm done with the boards, they will help to deflect the heat and also add a foot rest (highway peg ) for when I'm riding long. Wish me luck !
