Just can't come off the hip with 350 duckets for a tour shield, yet.
To start.....
While riding on the interstate, I put my hand up against the top of the shield and found how high above the shield is the horizon. I want to look above the shield at the horizon.
I went to Lowe's, bought a 18" X 24" X 3/16" piece of Lexan.
Cut a piece of cardboard 18" X 24". Marked center top and bottom.
Put cardboard up against BRP tour shield on the bike. Doing my best to find center, I marked the cardboard where I wanted the shield cut. Since I wanted the shield 24" above the center up-cut on the tour shield, I only had to mark one side of the board.
I then finalized the shape with a sharpie.
I then cut the cardboard in half, 9". I cut the board to shape (one side).
I laid the cardboard on the Lexan sheet, from center to right side. I marked the right side. I flipped the cardboard over, and marked the left side.
I used a jigsaw and cut the Lexan. I used a sander to round the edges and make minor adjustments to the shape.
I removed the shield from the bike and put it on the arm of my couch. I covered it with a sheet. (Make sure to find the center of the up-cut under the sheet, that is the center bend point.
I set the oven, which is 24" wide, at 450 degrees.
I put the Lexan sheet in the oven and at about 2 minutes, it began to flex.
Carefully, I removed the softened Lexan sheet from the oven and ran (safetly) to the couch and laid the Lexan sheet over the tour shield and molded the Lexan to (approximately) the shape of the tour shield.
After cooling, I remounted the tour shield on the bike and checked the Lexan sheet for fit.
I used "3M Dual Lock" discs to secure the Lexan sheet to the tour shield. Although I only had four sets, I set it and did a test ride up to 50 mph. I now get little puffs of air around my hair.
I just purchased 20 sets of "3M Dual Lock" discs from Laminar Lip for $10.00...will be delivered by next weekend. I'll use four alone the bottom, and two up each side to secure the Lexan sheet to the tour shield when done.
The gap between the tour shield and the Lexan sheet is about 1/4" because of the Dual Locks. This should be just enough air flow for hot days, but not enough for any concern otherwise.
I plan to do this again next weekend. The cut wasn't perfect....the proceedure for the oven must be altered, and the Dual Locks need to be positioned better. I'll take pictures of the second try. The first try went well enough that I think I'll go with this.
Lexan Sheet $15.00
Dual Lock Discs $10.00
Ice Tea $.75
Puffs of air....priceless.
:bigthumbsup:
To start.....
Lexan Sheet $15.00
Ice Tea $.75
:bigthumbsup:
