HowTo: MacGuyver trick to prevent your throttle spring from popping out!
The500thDaytona
Hey y'all! I'm installing heated grips right now and I'm sure any of you who have played with the handlebar know about the dreaded throttle spring popping out issue. While messing around I found a quick back to prevent that! The pictures below explain it better than I can in words. I hope this helps someone!
Nice .. Thank you. I have a new throttle side end bar to install after I "semi" stripped out my original tightening some hand guards. Basically a R&R of the right side throttle/switch assembly for the new tube. Any tips? Difficulty factor?
