Mac mini and Thunderbolt 2 question...
wyliec
I've done research on Thunderbolt 2, and I'm still confused. Before I ask the questions, anyone with a MAC mini, as I just purchased one.
I have 3 of them,not sure if the newer one hasT hunderbolt2 or not as i am using only
the USB ports. What do you need to know?
I'll be connecting the mac mini to a monitor. The monitor has an HDMI connection, as does the Mac mini. Would it be of any benefit to purchase a Thunderbolt 2 to HDMI adapter, and connect the monitor to Thunderbolt on the mac mini? I'm kind of fuzzy on the Thunderbolt connection, other than it's faster than USB 3.0, and HDMI.
For a standard monitor, even a 4K monitor, use the HDMI. For video, the issue isn't so much about bus speed, it's about bandwidth. That port has duel functionality - Mini DisplayPort when used for video, and Thunderbolt when used for data. So those adapters only utilize the Mini DisplayPort functionality of that port for video anyway, not the Thunderbolt data function. Same port, two functions, apples and oranges. The HDMI port is more than adequate and is designed for high definition audio and video. Don't over think it. Instead, save the Thunderbolt 2 port for one of these and use it for connecting peripherals. You'll be able to connect anything under the sun then.
https://eshop.macsales.com/shop/Thunderbolt/Dock/OWC/Thunderbolt2-Dock/
The Thunderbolt connections should be thought of more as a chaining feature rather than a digital link. As an example, I have an Elgato box with both Thunderbolt and USB connections, as well as video and audio. When I plug my laptop into it, it connects it to my Apple video display, and any phones or my iPad automatically connect.
Unless you buy other Thunderbolt peripherals, use HDMI for connections.
Yup, what the last two posters said. In reality, without Thunderbolt peripherals, it's really just a DisplayPort connection. HDMI is best for you.
