Luggage Rack
MNBK
Is there a luggage rack that is compatible on an F3T with the detachable passenger backrest ?
Thanks for any information provided .
Yes! The rack I installed on my F3S is MBL Innovations' newly designed F3 Rack.
I am also looking for a rack and are considering MBL Innovation´s rack. I wonder if it´s stabile? I guess it has a quite thick material but despite that it has no profile added for stability, it´s just flat metal in the part between the mounting and the actual rack...
Adding topcase
I think this rack will be quite stabile. I have seen a few installations with top cases attached to it - which I plan to do also next year.
One rack that does not impress me is the rack from BRP. I picked up a good deal on a used one from a member here, and will be giving it a try next week. It seems like the attachment is a little flimsy. I will definitely be placing light stuff there (maybe my rain gear). But I also mounted the Doc Humphreys rack to carry most of my wife's large assortment of stuff.
IMG_20181004_111437479.jpg​
IMG_20180828_211510544_LL.jpg​
I have the MLB rack. It is plenty strong and stable enough - a solid fit. I have an after market top case that I use with it. I don't like the look of ANY rack and/or top case on my F3T. That is one of the main reasons why I bought the F3T and not the LTD. However, I have been using the Spyder for work related trips :doorag: and I needed a more secure way of transporting my 17" laptop than strapping the LT pack to the passenger backrest.
The rack sits too high for my liking. It also blocks the saddlebag latches a little bit. In addition, the person who cut and drilled the antenna relocation plate had no idea how to use the tools to do the job. I had to clean it up and then I put electrical shrink rap on it to make it look better that the POS it was. The relocation works well with both the backrest and top box. BTW: BRP likes to Loctite things. Makes antenna removal a PITA.
My job is turning ideas into 3D computer models that can actually be manufactured. That is why I am called the CAD Dude. We have a pretty complete metal & fiberglass fab shop, along with a machine shop at work. So I plan to make a removable rack that sits lower and multiple top boxes for my specific needed - large for road trips, small for LT, dog carrier, etc.
Regards,
Don
I got the one from BRP and found it to be strong if not a little too small. I rarely use it but the times that I have it was adequate. I am a minimalist so the look was appealing to me. Works good with a cargo net from Harbor Freight. Once you mount it you will see it's plenty strong.
Flimsy ?
We just ordered one from canamspyderaccessories.com. It mounts directly to the BRP backrest.
I had looked at that one thought it wouldn’t be durable enough for my needs. I need something sturdy enough for a backpack with clothing plus a cpap machine on long trips.
Good luck and keep us updated on how it works for you. I have to purchase something by spring 2019.
Well, I gave it a try for our trip to spyder adventures. I think that it will work for me. But I will be keeping the weight down to a minimum. Probably going to bungee a little bag there with my travel spyder cover and rain suits in it. That way I will have easy and quick access if I should happen to hit a shower while riding.
You get
One rack that does not impress me is the rack from BRP. I picked up a good deal on a used one from a member here, and will be giving it a try next week. It seems like the attachment is a little flimsy. I will definitely be placing light stuff there (maybe my rain gear). But I also mounted the Doc Humphreys rack to carry most of my wife's large assortment of stuff. View attachment 166325View attachment 166324
Looks like you got the NFL package too
I actually stood on mine to change a light bulb in the garage.
