I can attest to off-camber roads being a real :cus: on the Spyder. Many a mountain curve has surprised me with a "weeeeee!!!" moment as a result.
That said, my observations:
1. It's not really necessary to do it while riding casually, but when riding technically, I *always* shift my weight to the inside. Even a single butt-cheek's worth of slip on the seat is almost always more than enough to keep the wheel planted.
2. The Spyder does have a *little* slip before the traction control kicks in. It won't kick the tail out as far as an actual drift, but there's enough there to help you around corners-- it just takes practice to figure out where the "sweet spot" of braking, cornering, and acceleration is.
3. An aftermarket anti-sway bar and upgraded shocks is always an improvement. The only downside to them, I feel, is that while it increases your performance margin, it simultaneously reduces your
safety margin. Meaning, with a stock Spyder, the Nanny will kick in long before you hit the edge of the envelope. With a better bar and shocks, you'll be able to take corners at greater speeds before the Nanny kicks in-- which means that, when the Nanny finally *does* kick in, it's trying to save you in a more challenging situation with a lot less margin of error. Thus, when riding, YOU are even more responsible for your safety margin. Caveat emptor.
Anyway, my biggest piece of advice while riding is to always expect the unexpected (which, I guess, makes it all expected, no?
). Every blind corner will be off-camber, covered in gravel, infested with deer, and half-blocked by a logging truck driven by a dozing 95-year-old wondering why he can't get his Jitterbug to text. Do that, and you'll be safe! :doorag:
