Low speed noise, and bogs off the line
rpdata
Hi All,
Picked up my roadster couple of weeks back, and just loving it(only 750km so far). But i have noticed some strange behavior, just wondering if anyone has noticed similar symptoms.
1. Once in a while off the line, it seems to hesitate and bog. ?
2. When nearing a stop or moving very slowly in and out of the driveway,
there's a strange rubbing noise, which can also be felt as very slight vibration through the handlebars...almost like the brakes are rubbing, but the brakes are not being applied....can also be similar to a loud squeeky rubbing noise.....sorry it's just difficult to describe. ??
Thanks !!
Rob
My vote = belt tension. Been there.
rpdata said:
Hi All,
Thanks !!
Rob
As far as the bog, is the unit warmed up or cold? You should let the unit warm up so at least 1 line is visable on the temp gauge.
The noise could be 1 of 3 things. Brakes (especially e-brake), belt tension or belt alignment.
:agree:
Even though I routinely take off right after starting the Spyder, it does run better after it has warmed up just a bit. I just know and expect that there may be some bogging down at first.
Thanks for all the replies! !
I'm convinced now the bogging is related to it being cold - as for the belt, and e-brake will have both items checked soon!!
Cheers,
Rob
