Low oil screen message
Sandy lord
So I was riding around town on my RT doing errands and stopped at a store. When I turned it back on, the screen flashed the yellow low oil screen. It remained on for just a few seconds then went off. The oil level is where it should be. Any thoughts?
That is not low oil level...it is low oil pressure. Probably a funky sensor, but your dealer should check to make sure.
My service manual says a "oil level sensor" refers to the brake hydraulic fluid level in the brake fluid reservoir.
Gets complicated when they refer to brake hydraulic fluid as oil.
were you parked on a slope..even slight slope? it could happen... then once on level ground all is good...
