BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
Do you know why the horn on your G/S , R/S , R/SS isn't very loud. It's because #1. it's facing backward's and #2. the cone is almost flush up against a piece of plastic......Soooooooo while I had the upper left side panel off ( the one with the scoops ) I took the horn off ( one bolt) removed their bracket from the back of the horn and decided if I flipped the horn over ( bolt is now straight down ) and faced the cone towards the front it would be right at the lower scoop....I made a small 90 degree flat angle bracket ...drilled a hole for the orig.horn bolt....drilled a hole in the plastic piece that was blocking the horn originally and another hole in the lower part of the angle bracket bloted it together and tested it ....It sounds louder now.....This was not checked via a decibal meter just my ear......this all makes much more sense if you are looking at the horn while reading this....Sorry still can't do pictures......Mike.......I know I'm BAD......
pps:
