J&M 40-ch CB Antenna Upgrade Kit for Can-Am Spyder RT.
This is a complete J&M CB antenna upgrade kit for the Can-Am Spyder RT touring motorcycle.
Included in this kit is a replacement brass mounting block that has been machined to fit in the exact same spot as the factory antenna block, but with the correct sized and threaded mounting hole, to allow the industry standard CB antenna staffs to fit, and to properly conduct RF transmissions from the CB antenna coax, all the way thru to the antenna staff itself.
Many of the Can-Am factory installed CB antennas improperly insulate the antenna staff from the brass mounting block, causing high SWR and poor CB transmission capability from the Can-Am CB radio.
This new kit from J&M includes a pre-tuned, (no SWR tuning necessary) 3’, top-loaded CB antenna staff, replacement CB antenna brass mounting block and complete installation instructions.
You will be impressed with the instant improvement in your CB transmission distance and sound quality to other riders in your group.
Installation is a snap, with normal hand tools.
http://www.jmcorp.com/ProductDetail....ctID=CSCBA-300
