Looking for used Garmin Zumo 590 or 595.
RogioS
I'm looking for a gently used Garmin Zumo 590 or 595. I already have the mount and power source that came with my 2013 RT Limited that I bought used.
Thank you,
Roger
Thank you,
Roger
If you've only got the 2013 GPS Mount, then I don't think the 590 or 595 Zumo's will work on it!! :lecturef_smilie:
Certainly here in Oz, & I'm pretty sure in North America too, the 2013 RT's came with a mount & power pin-out (BRP Unique) to suit the Garmin Zumo 660's - the actual connector part of the mounts were changed for those others, so unless your mount/connector has been changed to suit, neither a 590 nor a 595 will work on it!! :gaah: Do you really need to ask me how I know this? :opps:
Peter is correct. The GPS mount for MY 2013 is for the Zumo 660 and is different from and is not compatible with the pin configuration of the 590/595.
