Looking for advice on moving my master cylinder so I can replace the oil filter
So I see a top clip on it, but that just opens the lid.
Is there a trick to unclipping it so I can gently move it aside?
I looked in the manual and it shows me how to check the fluid level, but not how to move it out of the way
I never heard that the master cylinder, nor the reservoir have to be moved to do an oil change. But I have yet to do my first one - just passing on what I see on this forum.
Interesting question what do you have for a Spyder? I don't have the ans. for you, but I was going to look. Not sure there are any Spyders that require you to move the master cylinder to change the oil filter.
Behind the reservoir is a small piece of plastic, horizontal on top of the clip that holds it on. Slip that out, tilt the reservoir slightly, and lift. It will move enough to be out of your way to remove the oil filter cover. Cover hex is 36mm. Cover the area with paper towels, as it will drip. Remove old filter, drop new one in, replace O rings, replace cover. Call if you get stuck. Joe
There is a clip on the back side of the bracket. Unclip it there to allow you to move the master out of the way
I did my 18 F3L oil filter without moving the master cylinder. Was able to get cover out but was hard to clear housing. Didn't know I could easily move the master cylinder out of the way.
If you know the sequence for removal and replacement, there is no need to move the master cylinder to change the oil filter on an F3. Filter and cover come out together much easier than cover alone with its long center stalk.
I cant even see the filter housing when I remove the service panel. All I see is the master cyliner. Moving the MC is the only way to get to the filter housing.
On the F3-S the whole side panel comes off with only 4 screws and a couple of push pins. You can sit on a stool and reach everything in there.
If I were to buy replacement push pins, what would I buy? And what tool is needed to remove them?
Don't know the exact size. I got one of these bulk packs with 6 or 7 different sizes. I just pick one out that matches the old one. Tool comes with the bulk pack. You can use the other sizes on car door panels or something.
https://www.amazon.com/GOOACC-GRC-3...c+push+rivet+bulk+pack&qid=1581450666&sr=8-12
Can't hardly go wrong for $9. You don't have to replace them every time.
You can do the filter change without moving the reservoir, but it is simple, and makes more room. More importantly, it answers the OP’s question.
I found the same thing on eBay for $11.77 plus free shipping and they take PayPal, my preferred method for buying online.
Bend over and look at the side of the engine. You may not know me, but I run a Spyder shop and have done a few hundred oil changes on these. Yes, you can see and remove the oil filter without disturbing the master cylinder. Do it all the time.
Yes, you do need to remove the right side panel as shown in the photos above. The filter is clearly visible in the photo too with the master cylinder in position.
I completely agree with you. For me, I am simply scared about removing any of the panels besides the two service panels. I feel Ill never get it back together again.
