Looking for a Spyder key cover with a hole?! Any ideas?
Here you go a 2 pack for only $18.95
I have plenty in Stock
Give me a call 209-887-3283 7 Days a week Pacific time
No disrespect to the retailer, but those are practically useless.
You can't open the frunk with the key because it wont press deep enough (cover hits) and you have to superglue the halves together.
I drilled key like recommended in LaMonster video. Works fine.
I am sorry you had that problem but you are alone, I have been using them for years with no problems
you must have installed them wrong or if not, a nail file could remove a small amount of the plastic so the key
can go into the lock deeper. Super glue is a good idea as well. I will be happy to make a video and post it or send it to you
so you can see that they do indeed work very well and are not costly.
Dave
Key covers
:coffee: I got Motorcycle Dave's key covers and they worked great. I used model glue. My .05 tip. .....:thumbup:
Key rings just mess up the area around the ignition. I've never used a key ring, and only lost one key. And that was when I took it out of the ignition and
dropped it down into the engine area, and was never seen again.
I'm with Possible on this.
And even more important, with all of the reported DESS problems, do you really want to hang metal around the ignition receiver ?
My last 3 or 4 vehicles have been keyless; My last 2 motorcycles were keyless. I find that I am walking away from my Spyder leaving the key in the ignition.
I drilled a hole in mine as noted by others and put a key ring with a leather fob on it so that I would be more likely to remember to remove the key. I covered the metal bits with shrink wrap so they wouldn't scratch anything.
The only negative is that the leather fob part sometimes covers up the windshield and heated grips rocker switches during a ride.
Come on guys.... I now have one of each. I've had the plastic one's since I've had the bike and now the metal. So I have a key on each. I love them both. I've never had a problem opening anything. I glued the plastic one and locktighted the second. Choice is the name of the game....
Now play nice
