Good job! With all the different aftermarket ends and the changes BRP has done through the years, and the prohibitive cost on adaptors if you can get one, you might have found a way to make some extra money!
One thing you failed to put into the 2nd picture. A crimp tool special for the plug pins.
looks good.
What are the part numbers for the connector and pins
The connectors are the Delphi GT 150 series.
10 WAY MALE SEALED GT 150 CONNECTOR DELPHI 15326847
10 WAY FEMALE SEALED GT 150 CONNECTOR DELPHI 15326842
22-20GA MALE TERMINAL GT 150 DELPHI 15326268
22-20GA FEMALE TERMINAL GT 150 DELPHI 12191818
CAVITY PLUG GT 150 CONNECTORS DELPHI 15305171
22-20GA WHITE CABLE SEAL DELPHI 15366021
I did not order the blue seal. I worked around it. If you plan on using 16 ga wire like BRP you will need them for power and ground wire.
18-16GA BLUE CABLE SEAL GT 150 DELPHI 15366060
Excuse my ignorance, but in the pix you are showing 2 connectors on the bike side. I thought there was only one.I put together a powered 5 to 4 converter trailer harness this morning. It's for my 2013 ST limited.
The module, what exactly is it and do I need it?
On my hitch the space where the wire connector goes is round. Do I make a plate or do I put in some other connector?
Stefan
OK, if you can do it maybe so can I.
Any pic's on the soldered pin? and What are those tiny green thingies for? Cavity plug? Where?
Thanks
My harness hooks up the same place as BRP does it. There is a connector between the main harness and the harness going to all the rear lights. The trailer harness goes between this connector.
The module I used has 2 functions. 1st it is a converter to merge the brake and turn functions. The Spyder has separate amber turn signals and red brake lights. Most trailers are wired that the brake and turn functions are merged in red. This changes the number of wires needed at the trailer plug from 5 to 4. So if your trailer is 5 wire you don't need a converter or if it is 4 you do.
I see the connector "RTL" & "LTL" which is the connector before that that I need to tie into?
If you wire it with the module and you get a trailer with 5 wires, will it work?
Thanks,
Stefan
Which connector are we hooking into? In the wiring diagram I found the power output trailer coming off of fuse 7. it appears to connect to CIC2-H.
Am I connecting it to CIC2?
Stefan
The module I used has 2 functions. 1st it is a converter to merge the brake and turn functions. The Spyder has separate amber turn signals and red brake lights. Most trailers are wired that the brake and turn functions are merged in red. This changes the number of wires needed at the trailer plug from 5 to 4. So if your trailer is 5 wire you don't need a converter or if it is 4 you do. 2nd purpose of the module is to isolate the trailer wiring from the Spyder. There is a 10 amp power line in the plug provided by BRP for this purpose to power the isolator. So if something happens to the trailer wiring and a short occurs. The 10 amp fuse for the isolator will blow and the trailer lights will fail but the Spyder lights will be unaffected. I feel this is a good idea.
My hitch came yesterday and does not have a bracket like yours. I have not figured out how I am going to mount the plug. Just have not got there yet.
