Location of GPS NAV input for F3-T radio (cross-post)
Belrix
Anybody know which panel they hid the GPS input under for the F3-T's NAV input? I've marked it in red on the diagram.
-B
attachment.php
I am sure someone will reply with the exact answer you are looking for but in the meantime. The connector should be located near the power connector GPS2 also on your wiring diagram. Look on your wiring diagram for a legend that says the zone that connector is located. Also on your wiring diagram there will be a birds eye view of your Spyder with the zones identified on it. That should get you in the right area. I am assuming that the wiring diagram for the F3 is similar to all the past ones.
Can you tell me how you decided GPS2 area? I'm just trying to figure out how to do this on my own later.
I did find this, which seems like an unlikely location for the GPS input - under the driver's seat - and it seems to be some sort of connector. Still - it's worth a look.
attachment.php
If you're looking for hookup of the gps audio into the radio - and the location is same as my 2014 RTS, look on right side near edge of fuel tank. You'll have to remove some Tupperware.
attachment.php
The GPS2 connector is the power for the GPS. So the audio connector should be in the same area, probably zip tied together. Under the seat on the right side is similar to ST and RT.
