cougar
Anyone using one of these batteries? www.antigravitybatteries.com
:hun:Yes,Idid and they seemed to want to talk a lot about "smart chargers" in their FAQ.
Can this battery explode? I've heard of Lithium exploding.
No, this type of Lithium Iron Phosphate battery does not explode like some Lithium Ion batteries used for Laptop computers or cell phones (Lipo Batteries). Lifepo4 is one of safests most stable Lithium batteries available. It is actaully considered a "green" battery. I can be discharged then disposed of with no ill effects to the enviroment like lead or other lithiums. But EXTREME care must be taken not to directly short out the battery... these batteries are extremely powerful and will melt and smoke if shorted out.
Maybe I'm still missing something here but the battery in the Spyder RT is rated at 21 Ah where as the largest antigravity battery is 9.2 AH.
So, now do you see something that screams not to use this in a Spyder PL?
I would think that a 9.2 aH battery would not be a very good replacement for a 21 aH battery especially at $329.00 but that's only me.
As has been pointed out you can't compare a regular battery to an antigravity battery.
I don't get it. I know absolutely nothing about batteries but I do know a little simple math. A $329 battery lasts 4-5 years, they say. How many regular batteries can you buy for $329? I'm still on my original battery in my 08. So I have 3 years. I may have to replace it in the next year but at $100-$140. So where are the economics? :dontknow: To save a little weight? Heck you can add that back in a heartbeat by simply picking up a 6 pack(cokes, of course) and putting them in the frunk.
An Amp-Hour (ampere-hour, Ah) is an empiricle descrpition of a battery’s capacity.
That is to say, how long it will run before it is drained down.
The amp-hour rating for a given battery is the maximum amperage that can be drawn continuously until the battery is completely discharged over a specific time period.
Antigravity.. Does that mean that my spyder can fly???
Biggest amp draw on the Spyder, other than the starter, is the DPS. Beyond that think lights, heated grips, etc. The Spyder has a substantial parasitic load.That's 1 amp for 9 hours, or 9 amps for one hour, or 36 amps for 15 minutes, right?
I'm thinking that the suitability of a 9 amp hour battery would be related in the first instance to the electrical drain on the battery as the starter motor cranks the Spyder into life.
As you say, BRP mounted a 21 amp hour battery in the Spyder for a reason. One reason would be to cope with massive temperature variations around the planet, wherever the Spyder is sold and used, all year round. :shocked:
