Light Bulb Replace
Silvervette05
I have an 08 RS and I have had the dash out taken the rubber covers off the headlights to loosen the bulb to replace them, and for the life of me I cannot get the bulb loose, the book saids to turn counterclock wise, is there a trick to loosen it? Thanks Bob
Just changed mine to piaa 's. Same issue, so I took off the windshield and straddled the spyder from the front. A lot easier to get the hands on to turn the bulb and unlock it. Same thing going back in.
What are piaa's are they cheaper then the Bulbs I got Sylvania zxe $59.00 ?
Piaa night tech bulbs. Amazon. $43.00
There are a number of good aftermarket bulb brands out there. I get mine at buyheadlightbulbs.com.................................they carry numerous brands, their pricing is very competitive, and service has been quick and easy. You can go to more powerful bulbs (higher than stock wattage rating), but they can stress, or :cus: up you electrical system. The other route is to go to a whiter light bulb (bulb color is rated according to the Kelvin color temperature scale; BTW it has nothing to do with how hot the bulb is). HIDs are around 6000K; hence their intense white color (plus their positioning in relation to their reflector assembly, and reflector assembly design itself distributes their light very effectively).........................so I buy replacement halogen bulbs in the 5000-6000K range. They're not as good as HIDs......................neither is there cost. I'm pretty sure BHB.com lists the color temps for most, if not all the bulbs they sell. The bulbs I use are listed in my sig and are a 5150K color temp. I am very pleased with them.......................if you can get H7s in Luminics Ti White bulbs (they were out of stock when I ordered mine) they're whiter still at 5500K.............................got 'em in my car and they're the bomb!
