Try thisCan someone tell me where to place my ATV floor jack under my 14 Spyder RTL
mostly on what you are going to do. It will lift all wheels but also wobble. Won't fall off if doing normal work. Always good idea to have jack stands for heavier jobs. If cleaning it's good on the lift alone but more than that I set it down on stands. Can't ryde it like a mechanical bull...:roflblack::roflblack:
Best balance is with the outer rail at the end of the frame (further your on the pipe) inner rail towards the front. If too much boolean for you jack stands on front wheels and blocks under rear wheel unless working on belt tire etc the stand under shock...
Iguess my question was more ....where do you line the jack up. I think a different post said to line the front "blade" of the jack in line with the operator foot peg mounting point.
Can you add a "line up" clarification for us ? Thanks ! :thumbup:
view from the left side on an RS.
still good idea to check first few times. This may vary on the RT and F3...but this works for the GS/RS/RSS/ST..:thumbup:![]()
I'd like to get my Spyder off the ground for the winter to avoid flat-spots.Thanks everyone for the pictures, they really help!
-Fratz
Would this type of jack beappropriate?
And if so, is this the right one?
http://www.craftsman.com/craftsman-motorcycle-atv-jack/p-00950190000P?prdNo=2&blockNo=2&blockType=G2
