pwilbarger
Earlier this fall I managed to use my Pitbull motorcycle lift to put the Ltd on some dollies I had for easy farkling and cleaning over the winter. I ended using a piece of 3/8" x 4" poplar I had on hand on the lift where it contacts the frame due to the frame being somewhat recessed by the plastic belly pan plus there is a "thingy with wires" that hangs down on gas fill side that I had to be careful  of not hitting with the lift. It seemed a little unstable when lifted but I didn't take to the top (24" I think), only high enough to get the dollies under the tires. It was easier and more stable on my '10 RT and not as worrisome. Does anyone have any tips for when I reverse the process in the spring?
Spyder Phyl
2014 RT-Ltd, Cognac and Timeless Black 2010 RT-622 trailer.
Spyder Phyl
