Life expectancy of stock shocks
MRH
Well-known member
I'm wondering what others have found to be the well performing life expectancy of the stock shocks on an RT (I have a 2014 RT-S). My mechanic (who does great work and is very well respected) has suggested that they largely wear out around 15K with serious riding. I think I feel a difference, but it's sometimes hard to separate what is in your mind from what is real. He offers Race Tech shocks, which are great, but comparable in price to Elkas.
I have not replaced a single shock on any of the five :spyder2:'s owned.
36,500 miles on the 2010 and no need. Traded off at that point.
Coming up on 20K on the 2011 and 16K on the 2014.
No shocks needed in the near future.
23,500 and 25,000 plus on the 2008 and 2009. Both traded off at that point.
On our 2010 RT, I would agree with your mechanics opinion, original and replacement stock rear done in first 25K the Elka rear replacement still running at 52K+.
Have no experience with the 2014 shocks.
I have not drank on the new "high end" shock cool-aid yet.
I know Lou likes to push the Race Tech's and they are great shocks but in my opinion unless your doing a lot of hard riding, I just don't see the need!
Also be aware high end shocks like that need servicing every year so add that to the expense!
15K miles on my RT and no need for shocks at this time. The Bert's mega mall ride I really pushed my RT and proved to myself the stock shocks are fine for me. If I ever feel I need new shocks, I will buy the stock ones since they are proving themselves.
Bob
Ive put 6K on the Beast, bought last November with 4K on it and my original shocks are working great. I ride hard and they handle everything I throw at em. Still ride smooth on the interstates too.
funny how real expensive parts make you think your spyder rides better... maybe it because the difference in weight when they take a ton out of your wallet..:rolleyes:
osm
I have over 35000 miles on my 2914 RTL. I ride it as hard as humanly possible and my shocks are still great
Thanks for advice on stock shocks! See you have a Baja Ron sway bar, was it needed or just wanted? Cost worth the performance? I have a 2020 F3 basic, standard shocks and sway bar! I am a casual rider, maybe 3000 miles per year! Would sway bar make that big of difference? Thanks
I replaced the shocks on my 14 RTS. I would like to upgrade the 2020 RTL shocks. But find the prices rather high. The shocks on my 16 F3L were a much better quality shock. I also wonder about the shock adjusters that "BAJARON" sells. But I am not capable of doing the labor myself. Dealer labor is $$$.. :banghead: Tom :spyder:
What new features does the 2914 RT have over current models? Hover mode? Fully automatic transmission? Do they still have BuRP Connect???
I would say, rule of thumb would be an upper limit of somewhere in the neighborhood of 50k for most OEM shocks. That said, the 2008-2010 Spyder OEM shocks were abysmal. The 2010 RT shocks probably being the worst of the lot. All of the 2008-2013 shocks were under sprung and under dampened brand new. But BRP improved the RT shocks for the 2011-2013 models. Still underwhelming. But better. The 2008-2013 GS, RS and ST shocks were decent, but nothing to write home about. In 2014, BRP made some very real improvements in the RT shocks. And I believe they have continued to make, at least, small improvements in them, from time to time, until now.
I believe the RS & ST shocks also got some minor improvements over time until they were discontinued in 2016. The RSS always came with aftermarket Fox shocks, so they have been pretty good from the start.
The real issue with the 2014+ OEM shocks is the lack of pre-load adjustability. The Spyder frankly needs this capability to really get the most out of any shock. This is why all aftermarket (including the Fox Podium which BRP offers as an upgrade) come with this feature. The reason I started making the shock adjusters was because BRP finally came out with a decently valved/dampened unit. They aren't Elka's, of course. But adding the adjusters is pretty inexpensive. And a decent alternative.
One of the best things you can do for your 2013 RT (Budget) is to put a 2014 or later OEM RT Shock set on the front. You can usually find them fairly new and inexpensive from those who have put Elkas, Fox, Webber, etc., shocks on their ride. You will definitely notice a difference in ride and handling quality.
I have 35,000 miles on my Rt and the stock shocks are doing fine. I tend to corner aggressively at times and have made the following changes. BajaRon shock adjusters made a very noticeable difference on my 2015 RT. Car tires made a BIG difference. Sway bar not so much. Sway bar does make freeway riding a bit better when dealing with buffeting from trucks or sidewinds. Bike feels planted a bit better with the bar in windy situations.
Crazy Ron, this is exactly what you told me in PM email. Fox shocks on order, waiting on your swaybar. Thanks for the help.
I have a 2017 F3L and can I assume this bike has the same shock as the RT has, or is it a different shock?
If different, are the F3L shocks stiffer?
I see what appear to be adjusting rings at the bottom of the spring. Is it possible to tighten the spring with them?
SHHHHHHHHHHHH! He is one of BRP's pre testers. The bummer is that the newly revised RT will not be available until 2916. :roflblack:
SHHHHHHHHHHHH! He is one of BRP's pre testers. The bummer is that the newly revised RT will not be available until 2914. :roflblack:
By then if any of us are lucky enough to live that long, maybe, just maybe, BRP will come out with a shaft drive on their spyders. However, our descendants by that time may likely be piloting around in drones with no need or desire of owning anything that has wheels.
Consider Fox Podium series. I put these on 2013 along with Baja Ron sway bar. Fox series less cost than Elka, but still pricey.
IMO.....a shock absorber purpose is to stop Spring Oscillation......bounce test each side and compare. A new shock may be dampened differently,some have dampening adjusters. There is a TSB out there 13-5 on RS’s ,which addresses nose diving when stopping , states to replace shocks.
Oil viscosity may degrade over time may effect dampening effect.
If it leaks....that’s a no brainer.
Or.......treat yourself to a new set of shocks.....life is short!
