lets see if we could do this
cuznjohn
as i mentioned yesterday, it would be interesting to see what temps. the bikes are running at. all bikes are welcome to participate and i am not looking for any comments or bashing of the bikes or the company. i am really curious about the bikes that don't have any heat issues just to see what others feel is not hot. when i took my readings i had been for a 25 mile ride and the outside temp was 66 degrees, i took the readings with the bike in neutral and running, and when the fan came on is when i took the readings at the bottom right side vents.
so all are welcome to join in but PLEASE NO BAD COMMENTS OR DISCUSSIONS . THANKS
the temp. out today where i was, was 66 degree f. = 18.889 c
right side bottom vent 191.2 degrees= 88.444ºC
gas cap 159 degrees = 70.556ºC
right side top vent 164 degrees= 73.333ºC
temp gauge almost up to hot .
Altitude and ambient temps seem to have a lot to do with the perceived heat too. I for instance feel more heat if I'm riding in the upper 90s in Phoenix, rather than the same temps at higher altitudes. Not to make things complicated, but it does happen to be a more complicated issue.
TEMPS
TO ME IT REALLY DOESN'T MATTER JUST WAN TO SEE WHAT TEMPS PEOPLE HAVE
Be back..!!
only thermometer we have requires a tongue to put it under.. :roflblack: will get one and get back to you...
John, I assume your using the analog temp and fuel gauge? Have you ever tried unhooking the analog gauges and see what the digital gauges read? My digital gauge never goes above 5 bars. At 5 the fan comes on. When I had the analog gauges hooked up it never went above 1/2 way. Maybe your analog gauge is not reading right? I know this wont fix your heat problem but it seems weird to me that your gauges are actually reading so high. The fan should come on and drop the temp reading real quick. It seems like your fan is coming on way too late. Again not that trying this will fix anything but at least it might eliminate the gauge as a problem.
Bob
Bob
:agree: Digital is much more accurate Mine usually runs 5 bars when hot just at the edge (5.5 ?) of kicking the fan on I know it kicks in at 6 bars. How often is your fan on John? With some of the temps you are seeing I would expect almost all the time. :thumbup:
temp
yes i have a 28 dollar gauge i bought off of amazon and it is inferred and yes i went over to the digital on the dash and basically got the same temp readings
almost up to the hot mark i never read the bars but hot enough to melt the canister
Need to know how many bars. Have you ever checked your coolant level and I have read of someone having a thermostat installed backwards.:thumbup:
checked
brp told them what to check when they sent the buds report to them so i personally never checked, but the service manager is the one that told me brp is using a different coolant in their quads with a higher boiling point but they were not going to change it in the spyders. so my guess is that the quads are having hear issues also
