frank3
RT-S PE#0180
Cold here so I thought today would be a good time to start on the task of wrapping the exhaust on my RT. I've spent most of the day removing the front cylinder (left Side) header pipe. This is a BIG job. Couple of tips for those of you planning the same job. I spent over an hour trying to remove the pipe after everything was removed and loose. I was forced to remove the drive belt in order to have enough room to "move the pipe forward, rotate and remove under the left side lateral frame support". Got to tell you, there's not enough room with out having the drive belt out of the way. Other problem I ran into was having easy access to the nuts holding the header to the engine. I'm 6'-5, 230 lbs. with hands to match. Wanted to remove the screen and plastic from in front of the oil cooler radiator but found BRP didn't design this part to be removed without removing the front ot back engine support rod (the same rod that was added to the RS for 2011. Removing this rod is NOT an easy task but I got it out and removed the rod. Enough for today. I'm planning to take pictures of the process and post them along with any other unplanned removals I encounter along the way. STAY TUNED
