BOUGHT 2 LED LIGHTS FROM RADIO SHACK...MOUNTED THEM ON THE SPEAKER COVERS IN THE UPPER OUTER CORNER ON EACH SIDE...THE LED LIGHTS WERE THE TYPE THAT YOU WOULD PUSH THRU THE DRILLED HOLES AND THEY SNAP IN...ON THE INNER SIDE OF THE COVERS, THERE IS A SLOT TO PASS THE LED WIRES THRU TO THE WIRE HOLES GOING TO THE MIRRORS....TAPPED IN ON THE BIKE SIDE THE POSITIVE TO THE POSITIVE AND THE NEG. TO THE NEG OF THE LEADS GOING TO THE MIRROR TURN SIGNALS....REASON FOR THIS NEEDED ADDITION, HARD TO SEE THE GREEN TURN SIGNALS ON THE INSTRUMENT PANEL ESP. WEARING DARK GLASSES.....THE INSTALLED LED LIGHTS SHOW UP VERY WELL AND WARN YOU IF THEY DID NOT AUTOMATICALLY CANCELLED OUT...THERE IS A CHOICE OF EITHER A GREEN OR RED LED AND I CHOSE RED....I CONSIDER THIS A GOOD ADD ON....BTW, YOU HAVE TO REMOVE THE MIRRORS TO GET TO THE WIRING....
